Chane L3c
Sold Individually
Versatility and Fidelity
Chane's new L3c continues the success of the popular Chane A2.4 in an upgraded, up-sized main and center channel loudspeaker. Like all L Series models, the high performance L3c uses very high grade components, design, and tuning, including outstanding SB Acoustics drivers.
Exceptionally Capable in Many Settings
The L3c was developed for superb fidelity - this model is a mid-sized speaker perfect for any number of residential applications. Whether music, theater, or other media, the L3c packs a great deal of acoustical scale and power into a easy-to-place speaker with a symmetrical acoustical pattern into the living space.
High performance center or vertical stereo pair.
Use the L3c as a horizontal center or vertical stereo pairs. Three L3c make a perfectly matched, powerful trio in your next high fidelity LCR layout. L3c has the symmetry, the acoustical size, and the careful design envelope for tremendous acoustical scale and scope, while Chane's unrelenting tuning gives this speaker an enormously transparent, lifelike sound.
- 29mm ringdome textile tweeter
- 2x 165mm mineral-filled poly midbass drivers
- Tuned reflex bass system
- Dimensions - 335 x 520 x 235mm; 13.2 x 20.5 x 9.25in (DxWxH, as center)
- Weight - 35lbs
- Frequency Response - 45Hz - 28kHz (+/- 3dB)
- Impedance - 8 Ohms nominal
- Sensitivity - 90dB (2.83v, 1M)
- Suggested Amplifier - 20-150W
- The L3c is priced and packed individually in heavy foam cradles and a double-wall carton
- Includes Chane Music & Cinema's 30-day in-home satisfaction guarantee
- Five year warranty
- 29mm / 1.15" ringdome tweeter
- Twin 165mm / 6.5" mineral-filled polyproplene midwoofers with FEA magnetically-optimized motor
- Chane's custom precision dividing network
- Premium heavyweight braced enclosure
