Chane L7
Sold Individually
The Premiere Floorstanding Loudspeaker.
Over three years in development, the Chane L7 represents uncompromising design engineering in a sophisticated mainstay floor loudspeaker for home use. Chane's new casework compliments fine home interiors, and the L7's sleek, vertical proportions allow easy integration for such a capable design as this.
High Order Technology
Good looks may pass the test of interior style, but top-shelf sound is why users look to Chane. The L7's four reinforced aluminum low frequency drivers underpin Chane's unique mid-treble array of twin middle-range drivers, which flank the wideband 29mm ringdome tweeter in a symmetrical array. All are carefully integrated with our hand-tuned and CAD-optimized electronics for Chane's wide-open, musical, wall to wall sound.
What you've always wanted to hear
With good sources driving the Chane L7, users may enjoy a sound stage twice as wide as the speaker pair, with apparent images floating up through many feet of vertical space. Acoustical depth is extraordinary, and vocalists appear as if in real space - each individual acoustical source appears naturally and visually distinct, an advanced manifestation of the effect stereo was developed to portray.
The speaker you've always wanted to own
Chane delivers this sound and value customer-direct. All L Series models are designed and tested in the USA, and are offered with our satisfaction guarantee.
- 29mm ringdome textile tweeter
- 2x 115 Nomex midrange drivers4x 165mm aluminum bass drivers
- Sealed bass system
- Dimensions - 380 x 235 x 1175mm; 15 x 9.25 x 46.3in (DxWxH), not including base outriggers and hardware
- Weight - 75 lbs
- Frequency Response - 45Hz - 28kHz (+/- 3dB)
- Impedance - 8 Ohms nominal
- Sensitivity - 91dB (2.83v, 1M)
- Suggested Amplifier - 20-180W
- The L7 is packed individually in heavy foam cradles and a double-wall carton. Ships by truck.
- The L7 includes Chane Music & Cinema's 30-day in-home satisfaction guarantee
- Five year warranty
- 29mm / 1.15" ringdome tweeter
- Quadruple 165mm / 6.5" aluminum woofers
- Twin dedicated 135mm midrange drivers
- Chane's custom precision dividing network
- Premium heavyweight loudspeaker enclosure with molded fine pebble black front soundboard
- Premium cherry-walnut style enclosure case
- Styled black fabric grille with magnetic catches
- Acoustically sealed bass alignment
- Detachable machined aluminum floor outrigger arms with black anodized knurled adjusting knobs and stainless steel studs, and machined stainless steel carpet spikes and floor discs
