Chane 753
Sold Individually
"Stunning.  Mesmerizing.  Holographic."
We all want cleaner, more immersive sound. With a whopping six or seven times the acoustical size of little speakers plus precisely aligned acoustical tuning, the 753 may be a precision, pinpoint audiophile loudspeaker in its design tune, but it has the authority to illuminate a film soundtrack too.
Hear this preferred sound.  Chane's 753 floor speaker delivers enormous value in a well-designed home theater loudspeaker using premium components and a highly technical design platform.  The 753 absolutely loves to make music and cinema.  It's a Chane.
Final inventory closeout 9/2026.  Items are B-stock.  While they last!
Chane 753
$699$949
Power meets precision
With far more active cone area than average, Chane's 753 has clean output and excellent sensitivity nailed. But it's the careful driver choices, custom crossover engineering, and final tuning that give the 753 the wall-to-wall sound and superb focus that audiophiles crave.
This unique prosumer blend makes the Chane 753 special: Higher than average acoustic power meets Chane's emphasis on dialing in the underpinning design to deliver walls of natural and authentic sound. It's an uncommon entry in its class.
The players
Anchoring the 753's bass section is a trio of 8" ScanSpeak woofers in a sealed bass alignment. To this foundation a responsive, matching 6.5" midrange driver bridges the middle of the spectrum; its light cellulose cone delivering both signal-tracking detail and smooth response.
Perhaps most impressive is the 753's genuine 1" Italian compression driver by Eighteen Sound. It covers the model's top four octaves and with a constant-coverage aluminum horn creates the 753's exceptionally clean, uncolored, and dynamic treble range.
Alignment matters
Making it all work is a highly-developed custom Chane crossover network. It has Solen polypropylene capacitors and non-inductive audio resistors.
Well-managed acoustical behaviors and a balanced response deliver the 753's open, see-through acoustical presentation. They make real acoustical presence and power in user's spaces.  We'd like you to hear them too.
  • Frequency response, nominal – 45Hz – 22.5kHz +/- 3dB
  • Average bass response, room, calculated – 34Hz -6dB
  • Sealed bass system, attenuation - -12dB / Octave
  • Enclosure volume, bass - 71 liters
  • Impedance, nominal - 6 ohms
  • Impedance, minimum - 4.5 ohms
  • Sensitivity, calculated power – 92.5 dB (2.83v)
  • 1" titanium compression driver and 60 x 40 degree CD treble horn
  • 165mm treated cellulose midrange driver
  • 3x 210mm (8") poly bass drivers
  • Dimensions – 250 x 375 x 1236mm; 9.85 x 14.75 x 48.7in (WxDxH), with base outriggers and hardware
  • Net weight - 80lbs
  • Recommended amplifier – 20-200W
  • Driver-rated music power - 360W
Chane rates speakers sensibly, in accordance with acoustical physics and typical real use. Learn more about how speakers work here.
  • The 753 is packed individually in heavy foam cradles and a double-wall carton. Ships by truck.
  • The 753 includes Chane Music & Cinema's 30-day in-home trial guarantee and two year warranty (see Terms)
  • 1" Eighteen Sound constant slope treble compression driver: titanium diaphragm, proprietary phase plug, edge-wound high temperature voice coil, ellipsoidal suspension.
  • 800Hz 60x40 degree constant coverage (DI=11) aluminum horn
  • High energy 6.5" midrange with ventilated FEA-optimized motor, cellulose cone, and high temperature 38mm voice coil
  • Triple 8" ScanSpeak bass drivers with mineral-filled polypropylene cones, magnesium frames, and vented motors
  • Chane's exclusive three-domain-optimized custom crossover network, with time-aligned treble and linear phase rotation
  • Sealed bass alignment for lowest group delay and fastest sound
  • 18mm MDF cabinet, 25mm front baffle, and five internal braces
  • Simulated black ash cabinet case with molded fine pebble black driver baffle
  • Detachable machined aluminum floor outrigger arms with black anodized knurled adjusting knobs and stainless steel studs, and machined stainless steel carpet spikes and floor discs
  • Removable black knit grille with magnetic fasteners
  • Standard 5-way terminals and input cup
