![Chane L6](http://www.chanemusiccinema.com/cdn/shop/files/L6_1.jpg?v=1695075710&width=480)
![Chane L6](http://www.chanemusiccinema.com/cdn/shop/files/L6_2.jpg?v=1695075590&width=480)
![Chane L6](http://www.chanemusiccinema.com/cdn/shop/files/L6_3.jpg?v=1695075550&width=480)
![Chane L6](http://www.chanemusiccinema.com/cdn/shop/files/L6_4.jpg?v=1695075395&width=480)
Chane L6
Sold Individually
The Perfect Center Channel Match.
Your flagship floorstanding Chane loudspeakers need the perfect center channel companion. In the L6 we've recreated the exceptional fidelity of Chane's top L7 main speaker in a beautiful new horizontal center channel format.
The L6's exquisite design-tuning ensures a stellar dialog experience from modern home theater systems.
The L7's High Tech Match
The L6 dedicated center channel speaker borrows the Chane model L7's special aligned mid/treble cluster for precise intelligibility and Chane's renown musicality. As with the impressive L7, all L6 drivers are premium SB Acoustics components for maximum fidelity. We were first North American brand to deploy SB Acoustics because fine audio content calls for highest audiophile fidelity.
The L6 also uses a robust cabinet, compromising ten internal panel bulkheads between a pair of 25mm thick plates front and back to keep resonance at bay. Chane's fine exterior finishes and design lend the L6 the perfect complimenting L Series style.
- 29mm ringdome textile tweeter
- 2x 115mm Nomex midrange drivers
- 2x 165mm aluminum bass drivers
- Sealed bass system
- Dimensions - 335 x 750 x 235mm; 13.2 x 29.5 x 9.25in (LxWxH, as center)
- Weight - 52 pounds
- Frequency Response - 45Hz - 28kHz (+/- 3dB)
- Impedance - 4 Ohms nominal
- Sensitivity - 90.5dB (2.83v, 1M)
- Suggested Amplifier - 20-150W
- The L6 is packed individually in heavy foam cradles and a double-wall carton
- The L3 includes Chane Music & Cinema's 30-day in-home satisfaction guarantee (see Terms)
- Five year warranty
- 29mm / 1.15" ringdome tweeter
- Twin 165mm / 6.5" aluminum midwoofers
- Twin dedicated 135mm midrange drivers
- Chane's custom precision dividing network
- Premium heavyweight loudspeaker enclosure with molded fine pebbled black front soundboard
- Premium cherry-walnut style enclosure case
- Styled black fabric grille with magnetic catches
- Acoustically sealed bass alignment
