VotH Miami
Price per Pair
The higher energy classic loudspeaker.
96 dB, 10 Ohms, 36 Hz.
Alnico, Titanium nitride ceramic, veneer core joinery, stacked Birch laminate horn, foil inductors, alloy cabinet parts. Classic down-ported bass reflex in 135 liters.
Miami
Voice of the Home's classic, reference music playback instrument. Vivid, textural music from a slightly more compact, more contemporary form with higher sensitivity. Suitable for moderate-power single-ended tube amplifiers and above.
Baltic Birch horns are solid fine-ply laminate and clear-finished. Horns and/or cabinets may be stained for a fee. Contact us for this and other options.
Go into more depth about Miami in our forum.
*Sapele is a fine hardwood and may show natural hue variations.
  • 16" Alnico bass driver with cellulose cone and flat wire underhung voice coil for superb definition
  • 400Hz 90x40 degree laminated Baltic Birch broadcast-style top horn. 1.4" compression driver with nitrided titanium diaphragm, proprietary phase plug, edge-wound high temperature voice coil, ellipsoidal suspension.
  • Fine natural all-veneer cabinet. Computer-machined and hand-assembled in Upstate South Carolina. Cabinets and horns are finished in a hard, catalyzed semi-gloss lacquer.
  • Reinforced 18mm and 25mm veneer laminate plywood casework with constrained, damped internal driver board. Extensive four-ply viscous acoustical and vibration control measures on all interior surfaces
  • Optimally tuned reflex alignment for superb bass and extension. Down-firing.
  • Exclusive three-domain-optimized custom crossover network: Clarity PUR capacitors, Jantzen Wax Coil inductors, non-magnetic bifilar power resistors. Options available.
  • Premium quality biwired input terminals and matching output plate to horn driver terminals. Easy plug-in setup.
  • Miami ships with 6" solid metal legs installed
  • Miami is generally built to order. Kindly allow 4-6 weeks to-dock.
  • Packed individually in shipping cradles, double-wall carton, and palleted in pairs. Ship by truck.
  • Miami includes Chane Music & Cinema's five year warranty (see Terms).
  • Frequency response, nominal – 36Hz – 18.5kHz +/- 3dB; 20kHz -6dB
  • Average bass response, room, calculated – 32Hz -6dB
  • Impedance, nominal - 10 ohms
  • Impedance, minimum (bass driver) - 8.25 ohms
  • Sensitivity - 96 dB room; 93dB calculated power (2.83v)*
  • Dimensions, bass cabinet – 565 x 420 x 745mm; 22.25 x 16.5 x 29.3in (WxDxH). Add 6" for legs
  • Net weight - Approx 100lbs
  • Recommended amplifier – 3-100 W
  • Driver-rated music power, bass - 250W
*Chane rates speakers sensibly, in accordance with physics and typical real use.
